Seems we are always asking questions for a specific project, so I thought I'd start a thread on techniques for cutting mortice and tenons. I'm hoping people will be able to add any hints and tips, and photographs, make comments about both machine and hand cuts versions etc etc.
I cut some M+T recently. I used the woodrat for the tenones, and a morticer to cut the slots. I opted for shoulders to eliminate any risk of twist.
Cutting the tenons on the woodrat.
With the shoulders cut
Out the morticer:
Final cuts for assembly
The finished joint.
I'll start with a question then. I was told to always leave some excess on the mortice, which is cut off later. This ensure the morticer does no cause any breakdown - I've always picked an arbitary length - is it A) really neccasary:?: , and B) is their a rule about how much to leave?:?:
Also... when adding wedges - is their a rule about how thick the wedge should be at the oustide, and how far into the tenon it should go? :?:
Anyone else got any preferred techniques?
PS: Does anyone else nip of the edges of tenons - I did these on a stationary belt sander but I normally use a block plane. Is it really worth it?:?:
Out the morticer:
The finished joint.
