Jacob
What goes around comes around.
Moisture meter recommendations anybody? I've decide I need one. I've got some wet new joists ready for plasterboard and insulation, but don't want to shut them in until dry enough or I expect they will rot.
Yes I've ordered the very same from Amazon, slightly cheaper with postage free.CHJ":2p6po54h said:Jacob, I know you will probably find a need for a super accurate estimator at some time but as you have managed so far without one do you need anything other than a cheapy £20-30 jobie to check wet joists,I'm assuming they are rain wet not green timber.
NB the very helpful safety warning in the manual; "Be aware that the probe tip can cause injuries if used incorrectly...."CHJ":3usji3yo said:Those sound close enough to what I see with stuff stored from green to turned item with my cheepy device.
My quick check whenever I switch it on is to place the prongs across [not in ]a finger and expect to see 20% .
