I don't think I've made myself sufficiently clear. The panels are doors for kitchen cupboards, by the way, but that isn't really the issue. The issue is how thin can I make the panels before I run into problems of insufficient gluing surface to resist such forces as may act on the panels, such as shrinkage etc.
Obviously the thicker I make them the greater the gluing surface, but I also have to think in terms of what hardwood stock is available and the thicknesses whereof. If I use american hardwoods 1" stock tends to be 26, maybe 27mm thick. From stock of that thickness I should be able to resaw to get 6mm easily, 8mm maybe, depending on width (resawing inevitably producing some cupping). The easy answer is to go wider and use 1 1/2" stock, but then I might run into colour matching problems with the 1" stock used for the frames etc, and almost certainly the two stocks will come from different trees, maybe even different areas.
