orchard
Sorry to start another bandsaw thread, but i'd really appreciate some experienced help please. I find myself unable to decide between the single phase Centauro and Felder models, pictured below, and I hope a discussion may help others out too, because there's not a lot of information out there:
Data that i've managed to gather so far (please add if you can):
Model S500P CO 500HD FB510
Cut Depth 50cm 50cm 41cm
Throat 48cm 48cm 48cm
Table 50x70cm 62x45cm 50x64cm
Extraction 1x10cm 1x10cm 2x12cm
Blade Width 1-3cm ?-3cm 1-3cm
Cutting speed ? ? 25m/s
Flywheel speed ? 920rpm 850 U/min
Mitre Slot Yes No Yes
Upper Guide 'Precision' Carter 'High Precision' Ceramic
Lower Guide Wooden? Carter 'High Precision' Ceramic
Motor Protect Yes Yes ?
Power 2.5hp 2.5hp 4hp
Height 201cm ? 199.5cm
Weight 260kg 290kg 250kg
Aprx.Cost+Del £3,250 £4,200 £2,300
My initial thoughts are to go with the Felder, it has plenty of power (in theory), and is considerably less expensive, with the only compromises, that I can tell anyway, being a cutting depth of 41cm (which I can live with), a weaker fence imo, and build quality-which i'm less sure about, as from what I can gather, the Centauro's have universal parts that I think will aid its longevity -- I want this to be the last and only bandsaw I buy. Just how does the Felder quality and replacability of parts stack up to the Centauro's ?
Against the Centauro's imo are:
Are the Minimax guides bearings or solid like the CO500 ?
What's the deal with wooden lower guides in the UK with MiniMax ?
How can one use an accurate re-saw sled on the CO when there's no mitre slot ?
The big one, POWER, on paper, the claimed HP's have far weaker motors than the Felder, and even MiniMax in the USA have twice the power. Are they indeed weaker, or is it a marketing thing that disregards torque, or speed, wheel momentum or something i'm not getting ?
Thanks in advance
Nick
Thanks in advance
Nick
