mig welding setting
Alexfn
25 Jun 2015
Lanark
hi guys
i bought myself a mig welder, the best one i could find for the money came from poland, the only issue now is that i cant see that its possible to set the wire speed in normal meters per minute,
when i switch the machine to mig the wire speed dial actually reads out in amps it goes from 40 to 230
the only otter dials are for voltage and inductance
i know that normally if you turn up wire speed on a mig the amps also go up, but as its normally wires peed you set it at and i only have amps to go by im having to do a hell of a lot of trial and error
any pointers?
cheers
Amps or feed speed, Its always a guide that needs adjusting with trial and error anyway.
Is there are chart in the door to get you close?
If not have a google for mig weld amp charts.
