Microwave ovens
Phil Pascoe
29 Jan 2012
Does anyone have experience of the flat bed ones? Are they worth the little bit of a premium? We decided to go go for a fairly basic oven as we have never used them properly, just to half bake potatoes, heat tinned stuff and defrost, so the couple of decent ones we've had have been money down the drain, really. The penalty paid seems to be the loss of the grill - is there an enough of an upside to this?
gcusick
16 Sep 2019
Devon
I assume you mean the type without a turntable.
We have a built-in Neff one that matches our other appliances. It’s 900W. Works fine, though you do lose the entertainment of watching your dinner rotating. The upside is that cleaning up is easier after the inevitable explosion.
Terry - Somerset
22 Dec 2012
Taunton
If you think of a microwave as a back up device in case your normal cooker fails it can make sense to have the grill (+ possibly oven) functionality.
It may cost a small amount more than a basic one with a turntable. Note that built in would not be my choice - 3-5X the cost of a worktop model and if it fails you need to replace with one of the same dimensions.
Sachakins
You can believe it or not, that's your problem.
4 Apr 2020
Liverpool
Or use a standard one, with stainless steel facia.
William2020
6 Dec 2020
London
We went for a flat bed one from Panasonic last year and haven’t looked back. Our previous microwave rotated but was low powered. Current model is 1000 watts (although you can reduce it at the touch of a button) and I certainly don’t miss knocking the turntable as I’m putting something in. Cleaning is a lot easier!
