DiscoStu
So as I mentioned in a previous post I am looking to make an MFT style top.
My initial thoughts were that I would have a 25mm wide by 13mm deep channel cut out where the edge of the rail would sit so that when I cut I don't mark the table. The plan is / was that I'd have a channel near the top edge and on the side edge.
I also wondered about inserting some T Track that would enable me to use a stop on it so I could easily do repeat cuts of the same length.
Now this is all well and good as long as I always want to use the same horizontal and vertical cutting points but how often will I want to make a cut in the middle of the table?
Why do those of you that own an MFT style top do?
I've created a sketch up plan so I'll try and add an image shortly so you can see what I am talking about.
