Steve Maskery
There are occasions when I want to cut of multiple lengths of board on my MFT. I have a couple of ways of making this easy and accurate, and this is my latest.
It is an adjustable length stop which fits into two holes of my MFT, and consists of a pegged base over which slides an adjustable foot.
The holes of an MFT are on 96mm centres. If it seems like a strange distance, it is because it is compatible with the 32mm system. So the two peg holes have to be drilled exactly 96mm apart. To do this I cut a spacer exactly 96mm long, put the workpiece up against a stop to drill the first hole, then inserted the spacer to drill the second hole, ensuring that they are exactly the correct distance apart.
Then, over on the Router table, I routed a v-groove across the top of the base and along the centre of the top.
Still on the router table, I used the Dropping On method to rout a pair of 1/4” grooves along the sliding top, taking just a few mm at a time, each cut being braced against the RH stop before being lowered onto the the cutter and pushed forward up to the end stop.
