- Joined
- 11 Mar 2009
- Messages
- 1,321
- Reaction score
- 11
I recently built a tv cabinet which I sprayed white with a water based finish. The unit was in the garage loft for the summer and the mdf carcass and poplar frame on the front shrunk as the invisible joint which I spent a long time getting became visible. I then resanded it back down and resprayed the unit. It looked really good.
I brought the unit into the house. The same has happened again and I am trying to work out why this is happening. If I was to use an oil based finish would this make the unit less susceptible to the unit being able to take on / lose moisture?
