GrahamRounce
Hi - why are the cutting tips of masonry bits wider than the shaft? Especially with larger holes, it means the bit wiggles all over the place and you can't get a nice parallel-sided hole for eg 10mm cylindrical expansion bolts (my current problem).
I'm thinking of finding a bit whose shaft is 10mm, then grinding down, if possible, the cutting thing to 10mm.
Any comments please?
