Marples 2" bit
Racers
22 Apr 2005
Hi, Chaps
I finally got round to cleaning and sharpening the 2" marples bit I got from the car boot sale.
I made a quick handle for it as its too big for my braces, it didn't last long it needs to be thicker.
It takes some turning :shock: and could be sharper, didn't leave a good hole in some cheap pine, maybe some better wood would help.
It makes very big chips.
Probbaly because of the coarse lead screw.
Always handy to have a bit on the side I say. especially such a big bit ! :mrgreen: :shock:
Hi Pete,
I (my arms and shoulders mostly) have come to the conclusion that such wide bits with coarse screws are intended for green wood.
Also the type without the sticky - outy sharp bits on one side or both (there's probably a technical name for them) are never going to make a clean entry. I wonder if mortices would be pre - scribed/shallow cut with a chisel first ?
Hi, Richard
Yes, green oak would probbaly be a good choice of wood.
The first couple of chunke of wood I tried it in just split when I was half way through!
Spurs?
Pete,
As it hasn't got a spur, should the sides also be sharpened, so that the cutting edges and the sides form something like a corner chisel profile?
It looks like it's been sharpened a fair bit down the years - I'd have hoped for a slight "M" shape, rather than a "^" so that it starts to cut at the edge rather than in the centre. All mine have spurs though, which makes a lot of difference.
E.
Pete's is a "Scotch" pattern auger - the sort with the extra cutters on to make the initial score-cut is a "Jennings" pattern which I think was a later invention. But I suppose if you sharpen the side cutters on a Jennings bit till there is nothing left, you will end up with a Scotch bit or something very much like it. Richard may need to borrow it when he gets round to making those lock gates he's gearing up for!
Andy , ... again with the lock gates;... although it would be a great project, I think people round here would probably object. This is a particularly flat section of The Grand Union and an extra one or two lock gates snuck in would just confuse things. #-o
Though it's a tempting idea - all that iron work too ....
