cjard
The next major task I'll need to attend to with my building project is skirting, architrave and door cases. I'd like oak, but quotes are coming in somewhere around the eye watering mark. I've estimated I'll need around 500 linear metres of skirt/arch and I'm toying with the idea of making it instead of buying it
I see I can get pallet loads of oak of a sawn thickness, varying but reasonably consistent width (120mm) and long length for around 950 quid a cubic metre (27 quid a cu ft) and I'm guessing I'd need a planer/thicknesser to tidy it up. I'm not after any fancy profile, I actually just want a rectangle section with a groove near the top- I can do it on the table saw I reckon
I've got 3 phase power available and I'm not afraid to put the necessary money at getting the right tool (given that PAR seems to be 3x the price of sawn..); looks like 500 quid tops would get something secondhand that'd be good for the job.. I may also be able to borrow use of one in someone else's workshop and just buy him a new set of blades and some beers as a thank you
A few questions:
Is this a fools errand? Will I buy a load of kiln dried sawn timber, plane it, fit it and then find it warped all over the place in a years time?
How many sets of blades will I go through/how long would a set reasonably last on oak?
I don't really care if the faces aren't perfectly parallel cos it's only skirting, so do I need a thicknesser or will a planer do? Is square cut timber near enough square that planed faces would only be at most a few mm out of parallel?
If a planer/thicknesser was only 50% more money than a planer, is it a worthwhile investment?
Am I correct in thinking that a table top p/t isn't going to be up to the task, and I should be looking at something floor standing, 16 amp or 3 phase? E.g a record pt260, or would a good portable one be more useful/adequate/easy to store?
Is 950 a cube a good price for kiln dried oak?
Thanks guys
CJ
A few questions:
Thanks guys
CJ
