Giff
I am making some wardrobe doors about 2m x 350mm. The idea is to use small disc magnets set in to the door and the frame . Has anyone done this ? what do I use to stick them. What size magnets do I need ? Thanks Geoff
Giff":zubvgp9z said:I am going to try the 10mm discs and if they are not strong enough I can double them up.
custard":2mhazis9 said:Giff":2mhazis9 said:I am going to try the 10mm discs and if they are not strong enough I can double them up.
Geoff, in my experience it's more likely that the magnets will be too strong rather than not strong enough.
If the door's mainly made MDF or ply or chipboard it can resonate and flex when opening against the pull of the magnets, which makes the unit feel a bit cheap. I'd get the smallest magnets you can find...or have beefy oak rails and stiles!
Cheshirechappie":1tgsbs22 said:I reckon adding the veneer about halved the power of the magnet, but it improves the 'finish' markedly.
Register today and take advantage of membership benefits.
