fluffflinger
Sometime ago I acquired, for the princely sum of my labour to load and unload plus £40 in diesel 3,200 linear feet of 100 plus year old pine floorboards from the demolition of an old factory. Well to be accurate they are not floorboards but 16ft roof boards, good news is that they only had 8 nails a board (yes I de-nailed all 200 of the little fellas).
Now I want to use them as flooring in my early Victorian Stone Cottage and the small sections I've cleaned up and oiled look great (will start another thread on finishing when I get done with the surface preparation).
The boards are T&G with a bevel on the painted side (did I not mention that they are painted on one side?) So my dilemma is how to prepare the reverse side to a finished standard as it dirty and discoloured. Also should I remove all the old paint from what will be the underside? Not many of the boards are cupped but I would prefer them to be able to breathe all around.
My choices are wreck a set of blades or two on the surface planer (I have a cheapo benchtop model) run them through my thicknesser (DW733) and have the blades resharpened a time of two or build a drum sander (simple version based on an old Nu-tool lathe that lies gathering dust under a bench) load it up with 40 grit and let rip.
Any suggestions would be most welcome. I want to get this job done soon I can so as to get them inside acclimatising before laying in the Autumn. I know you will all think I'm mad but I relish the challenge and I'm a great believer in a "2nd life" for any timber as this stuff was destined to be dumped. Plus they are after all lovely bits of very old pine!!!
