Loose tonge M&T
Freetochat
14 Feb 2005
Suffolk, UK
I am thinking of trying loose tonge M&T for a coffee table (Similar to the Trend Beadlock Joint). Is the joint as strong as a normal M&T joint? The joint will be in hardwood.
waterhead37":opmkdsyf said:
The joint is as strong as a normal M&T made to a comparable standard.
I agree, every bit.
One of the many advantages of loose tenon joinery is that you can get your shoulders to meet all round very easily - just make sure the rail has a square face. If you use a router to create your mortices, by referencing off the front face every time you don't have a problem ensuring that the the tenon isn't quite in the right place within the joint. There are lots of advantages. I've used loose tenons for years and never had a problem.
I'm making a bed at the moment and using "proper" M&T's - I'm having a job remembering how to do it! :)
Have you seen the new Festool Domino? It's a dedicated loose tenon machine, a bit hefty, but works superbly. I have a review of it in this month's GW. The only downside to it, as far as I can tell, is the fact that it is limited to a maximum tenon thickness of 10mm (so 1/2" is out for big doors, for example) and the plunge depth is limited - can't remember to what - but again, it means that big stuff is out. Oh yes, and the price!
But otherwise, for small and medium-sized work, and in a production environment, it's absolutely great.
Still, you can do a fine job with a little router and a jig or two, go for it!
Hi Steve
You can always put multiple tenons in side by side.
Neil
I had been looking at the Leigh FMT, but finding it difficult justifying the £600 plus setup costs. Buying the Trend setup would be about £100 (Including kit and tongue cutter). Even cheaper would be designing a jig to do the job. My next task.
Thanks for the imput.
Regards
Regards
I make my own by hand & machine.
I have also used the beadlock system and it's very good imho.
No need for expensive jigs. :)
Thanks I'll look for the article when my copy of GW arrives. Hopefully Festool will have it on their display tomorrow at Wood 06. I saw the tongues for this machine is 20 to 25 mm, Hopefully that would be strong enough?
