LED panels
Phil Pascoe
29 Jan 2012
A couple of years ago someone recommended these - https://www.ebay.co.uk/itm/400921892859
- I've just bought one and they are brilliant (both senses of the word). When I looked at the company to see if they were cheaper direct (they're more expensive direct) I noticed that they do wire kits to suspend them - £7.99 for one, but decreasing the more you order - I'm ordering another panel, and an acquantance is ordering two so four kits were £19.99. They are quite neat and allow hanging up to a metre down, and tilting.
I should have included the link - https://www.energylightbulbs.co.uk/prod ... ing-panels
Garno
Grumpy Old Git
21 Oct 2017
Dronfield
They seem very bright, 48W LED that will burn holes in the floor :D :D
Steliz
Camberwell Carrot
11 Dec 2017
Hungary
I also bought some, built some frames and put them up in my workshop. They are great, definitely reccommend.
RogerS
20 Feb 2004
In the eternally wet North
Me too. I have ten plus spares.
The colour temperature is so close to daylight, one guy that came to visit was convinced they were light pipes and stepped outside to check !
The only problem I had (and which explains why I was given four spare !) is that the glue used in the construction softened when the lights had been on for a while and so you could see the row of LEDs very clearly. I've lowered mine to get a bit of ventilation above them to mitigate any likelihood of failures.
novocaine
21 Jul 2014
Warrington
Phil
Does it say how much space is needed behind the panel? I'm wondering about surface mounting a couple but need to make sure they can be attached to the ceiling in this way.
flying haggis
7 Mar 2009
norfolk
that workshop is faaaaaaar too tidy!!
MikeG.
24 Aug 2008
Essex/ Suffolk border
On the strength of this thread I have ordered one of these panels...............so you guys better be right or that's £18.99 wasted. I can see me having 2 or 3 more above the busier areas of the workshop if this first one works out OK.
MusicMan
1 Jul 2015
Warwick
Me too, and me three since I ordered two, one for a newly-boarded loft and one for the utility room. Exciting stuff.
MikeG.
24 Aug 2008
I've dug deep enough already just buying the light. I'll find some way of hanging the thing from the ceiling, without forking out for a hanging kit. What I'd really like to do is to have it on some sort of moveable arm so that I can swing it into various positions.
lurker
Le dullard de la commune
2 Mar 2007
Leicestershire
I was getting worried about my eyesight where fine work was concerned,but now I have fitted these I find I am fine.
lurker
2 Mar 2007
Leicestershire
I suspect that you will not need them on an arm, once you see how bright they are.
Dibs-h
23 Jul 2007
Bradford, West Yorkshire
I take it you couldn't mod\butcher something like (which isn't tiny)
to give you what you want? Or a much bigger arm?
MikeG.
24 Aug 2008
The problem is that I have a sloped ceiling above my bench, and part of it is occupied by a hinged internal security shutter that folds down to cover the window. This leaves only a small area for a light, and it is at least partially above and behind me, so may actually cause some inconvenient shadows. Still, I'm looking forward to the brightness.
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
These things are easy to modify if you need to. If you unscrew the edging strip, you will see that the lights go only around the edges. The surface does the diffusing. So if you needed to reduce the area I'm pretty sure that it would be a straightforward job.
Usual stupidity disclaimers! :)
RogerS
20 Feb 2004
I simply made some lengths of rebated stock from offcuts and screwed them to the ceiling. Initially tight to the ceiling but them I noticed the backs got quite warm and as they heated up my problem arose...so I just got longer screws and let the rebated stock dangle a bit giving me about 10mm of air above.
RogerS
20 Feb 2004
You should have seen it two hours later :oops:
Mrs C
3 Jan 2016
United kingdom
A couple of years ago someone recommended these - 48W Ceiling Suspended Recessed LED Panel White Light Office Lighting 600 x 600 | eBay
Hi
Resourecting an old thread, what space did it cover? New workshop is 4m x 5m, so would 2 do the job or do I need more? Thanks
