Leaky Shower
Fecn
29 Aug 2006
Wilds of Surrey
I fell guilty that I've hardly seen the inside of my workshop this year, and have scarcely had time to read UKW. Whilst I've got a couple of hours of peace and quiet (finally) I thought finally get around to posting something here, but since it's not woodwork related it's here in General Chat.
A couple of months ago I took my coat out of the cupboard downstairs and discovered it was going moldy. The back wall of the cupboard was very damp to touch, and the paintwork was starting to flake away. There was only one place it could be coming from... the shower. I usually have baths myself with my wife using the shower.
Whilst my wife was out one Thursday, I decided it was time to investigate and see if I could fix the problem. I pulled off a few tiles in the shower and found that the wall underneath was soaking.. as was the floor... as was pretty much everything. I pulled off some more tiles to see how far the damp had spread. They were so damp they practically fell off the wall. I kept pulling off tiles until I found where the damp patch stopped. I'd pulled off most of the tiles in the shower by now, but still the damp went further, so I removed the shower door, and pulled off some more tiles - Found all the damp - Hooray.
Since I wasn't keen on the old tiles in the bathroom I figured it was best to carry on taking them off the wall, so I removed the sink, the loo and the towel rail and kept on going. Once I'd got all the tiles off the wall, I figured that if I was re-tiling the walls I might as well sort out the horrible cork-tile floor too. The cork tiles were glued down with some kind of indestructible glue which I just couldn't shift, but I noticed that they were all stuck to a sheet of 12mm ply. I grabbed my cordless circular saw and cut the ply into easy-to-remove pieces and chucked it all out.
Under the plywood I found some very knackered looking chipboard which had been cut into several pieces when the central heating system had been upgraded many years ago. By now we were planning on a nice granite tiled floor and I knew I'd need a good solid base, so I got rid of all the chipboard too.
Once the chipboard was all gone, I discovered that the back block wall of the cupboard had been built directly on to the chipboard floor and had sunk slightly as the floor had moved. I decided that it could do with some reinforcing. Every shower I've ever seen fail has been because the floor moved, so I decided that I'd do everything I could to eliminate movement from the shower base.
I built a couple of brick pillars under the wall of the cupboard.
I decided to install a 45mm thick wet-zone shower base which I wanted to set down slightly below the rest of the floor. I needed to remove a 27mm from the beams under the shower base. As the cupboard wall was now supported by brick pillars, this was safe to do. I made a quick letterbox-style jig from some 12mm MDF and then routed away the tops of the joists to the right depth. Finally I chiseled out the bits I couldn't get with the router. I also added some extra support props under the rest of the joists to reduce the flex, and put noggins in every 12" to further stiffen things up. Rock Solid!
I fitted a new floor using two bits of 18mm WBP hardwood ply, and then fitted the shower base. I had to increase the drain diameter to 2" which meant fun and games with the soil stack. I also added some extra 15mm plastic plumbing (insulated of course) under the floor so that I could run a shower pump to the new shower.
I boxed in all the pipes with some 12mm MRMDF
Fitted the shower pump... 22mm copper for hot and cold to the pump... 15mm plastic from the pump to the shower.
Sealed around the shower base with a flexible rubber strip and some rubber paint.
I did some tiling. I got to buy myself a nice large capacity tile saw for this job, so I quite enjoyed it. I do like my power tools.
I'm particularly pleased with this tile - Amazing what you can do with an angle grinder.
This shower base was easier to do than it looks.
I used bleach, Cillit Bang and a pressure washer to clean up the the old loo and sink in the back garden. I used clear sealant for the join from black to white... And here's the finished result.
I rounded over the edges on the windowsill using a mixture of angle grinder, belt sander, ROS, hand sanding and polishing wheels.
Oh.. and whilst I was doing all that, my wife was working on this
Ah well.. looks like my peace and quiet is over.. time to do some more work. Hope you enjoyed this diversion. Shame it's impossible to get a decent photo of the whole room.
Rich
12 Mar 2007
Reading
Very, very nice, and the added bonus of doing it yourself, a man after my own heart, you never know what your capable of until you try, admittedly, decent tools make it easier, but it's having the will to do the job in the first place that matters,
well done and thank you for showing what CAN be done, oh, and take your thumb out of your mouth as well. :lol:
Regards,
Rich.
Daven
17 Jul 2008
Devon
Excellent - the only problem I can see is you may have problems with leaks over the next couple of years from the bit of kit in the last picture :lol:
Congrats
Dave
Vormulac
10 Oct 2004
Uxbridge, West London
Typical woman, left you to get on with all the hard work! :wink:
Good work on the bathroom, it looks amazing! And congratulations to you and your other half of course on your new addition, you thought you didn't have any time to do all those little jobs before? You ain't seen nothing yet! :lol:
wizer
3 Mar 2005
Congrats Fecn, it's amazing what you can set that CNC to do! ;)
pren
13 Feb 2008
Gogledd Cymru / North wales.
See, I'd have just moved the coats to another place .... :roll: :lol: :lol: :lol:
Excellent work!! I do like the level-entry shower. Thinking of doing something similar myself. Did the base come as a kit?
Bryn :D
Fecn
29 Aug 2006
Wilds of Surrey
Rich":3qp9594g said:
Very, very nice, and the added bonus of doing it yourself, a man after my own heart, you never know what your capable of until you try, admittedly, decent tools make it easier, but it's having the will to do the job in the first place that matters.
I now apply the thousand-man rule to anything I want to do. If a thousand other people can do the job (tradesmen etc) then I can probably work out how to do it too.
So what did you do on Friday?
Went to the pub of course... I figured I deserved a beer by then. It actually took nearlyt two months to do the whole lot... Three weeks of evenings/weekends to do the work, and a further 32 days waiting for Tile Depot Croydon to get the last 5 tiles I needed to finish the job.
Raggy":3qp9594g said:
Fancy coming to do mine next Thursday?
Let me think long and hard about that.... No!
With new babies come grandparents... and with grandparents come the ability to abandon all parental responsibilities and hide down the garden. I even found time to re-oil the gate. Plus.. the little guy's going to need his own toybox or he'll be jealous of his sister's one.... and maybe another nappy changing station too.... If only this promised recession would hurry up and kick in and I could get away from this pesky PC a bit more often.
Too many toys - never enough time. I've got a half-finished CNC project that's been sitting in the shed since February - It was originally going to be a birthday present for someone in April, but I guess it'll be a christmas thing now instead.
Yes - It's the iBase kit from riverbed.ltd.uk - It cost around 350 I think. The kit came with the drain ready-fitted and with the rubber sealing strip and rubber paint. I got the 1000x800 size and then trimmed it down to the 950x760 I needed using a ktichen carving knife. The shower base is a kind of high-density polystyrene that they seem to be calling 'architectural foam' these days.
wizer
3 Mar 2005
I'm going to look into those kits. I have to rip out a nearly brand new bathroom suite because the guy my Dad paid to do it was a complete moron.
Digit
11 Nov 2007
Wales
The start of your journey Fecn reminds me a similar list in my life.
Our last house had a brick and tile lean to coal shed, and when we moved in I noted a couple of tiles needing to be replaced.
Eventually I got round to it and purchased two tiles.
'Big job I see' was the suppliers comment.
Little did I know.
When I started I found that the tiling battens were rotten, so strip the roof and remove the battens. It was then that found that the roof beams were also rotten, so off they came.
Then I found that the wall plate was rotten, so off that came as well.
Then the wall fell down! :lol:
Roy.
