Lathe hand wheel
wardroom
11 Jan 2010
Wallington, surrey
I have a delta lathe and I wish to get a hand wheel, but am having trouble sourcing one in the uk.
Any help would be great.
Not able to download picture of lathe at present. If I remember the model is something like 46- 255
Thanks in advance
Are you referring to the tailstock handwheel or are you trying to locate one for the rear of the main spindle (left hand of headstock).
I am referring to the headstock (left hand side)
Is the lathe of the same sort of pattern as this Axminster model?
If so I don't think I've ever seen a handwheel listed as an accessory. Think you would have to turn one up yourself and devise a suitable fixing.
That's much the same headstock arrangement as many others sold under various brand names. Don't remember any thread fittings on the version I had some years ago that would allow easy fix of a handwheel.
I think the end of your headstock spindle will look something like this.
if that's a parallel sided hole in the outboard side of the headstock, you could turn an "inside out collet" (like a Fischer fastening) to fit into there, with the handwheel secured to it by the bolt used to expand the fastener. Could be done in wood, or you are into metalworking, then there's a relevant design in Sparey's "Amateur Lathe" book.
