paulm
IG paulm_outdoors
My 18 month old Sony Vaio laptop pc had an unfortunate accident last night. It was standing on edge on the floor beside the sofa, charging up, when a glass of water was knocked over and some spilled over it
Didn't seem to get very wet so I dried off the little there was and finished dinner. On trying to start it later from the sleep mode it had been in with the lid closed when it got wet, nothing would happen, completely dead, wouldn't power on again when on mains or battery, so put it into the airing cupboard overnight with the lid on the pc open to let it dry out.
This morning when I opened the cupboard there were two lights on the pc that hadn't been lit before, one being the green "on" led on the front and the second being the orange "battery charging" led also on the front. Youngest daughter had also noticed the screen lit during the night apparently, although it wasn't when I put it in there and wasn't when I took it out this morning.
So far I have managed to establish that those two lights stay on when the battery is left in or taken out as long as the mains is plugged in, the lights stay on when the battery is in without being on mains, they only go off when both the battery and main are unplugged.
The computer will not start up with the battery in place, whether or not the mains is plugged in, but will start up with the battery removed and only the mains plugged in, it then runs normally for 10 minutes before switching off suddenly as if the power had been switched off.
There are no power saving settings currently on as I switched them all off this morning to make sure it wasn't something like that (although they probably were on before which might explain why the screen turned itself off during the night, but not why it came on by itself!).
The battery power level looks okay, shows about 80% and was charging successfully.
I swapped the mains power block and lead for a spare with no change.
The pc wasn't getting particularly warm before it shuts off, and as far as I can tell the fan was working okay, although it's always been very quiet.
Have tried using a hairdryer on a cool setting on the various vents in case there was some residual moisture, but no real progress today
Will try leaving it in the airing cupboard again this afternoon and overnight, but any other ideas or thoughts most welcome, reluctant to give up on it too easily as it is relatively new and decent spec
Cheers, Paul
Cheers, Paul
