Landrover TD4 replacement clutch :-(
flanajb
11 Mar 2009
For some reason my Wife insists on having a Freelander TD4 and the garage have just told her that the clutch has gone and it is going to cost £1200!!
This seems like heck of a lot of cash.
I'd get prices from elsewhere first. Sounds like a hell of a lot for a clutch job.
Si
I run a Garage for a living, see http://www.gilmortongarage.co.uk , and this price is realistic.
The freelander is easy enough to do but there is alot of components to remove.
You should be having a dual mass fitted, and also a new concentric slave cylinder, because if
these fail 2k up the road, the same labour and inconvenience will be repeated.
Liam.
It looks like it's about £600 worth of parts plus consumables and it's worth changing the slave at the same time. I would check that's what they are planning to do and if they are it seems realistic. I've done a disco one and one was enough!
Thanks. It does seem like a fair prce. Boody waste of money in my opinion.
I could buy a new PT with that money :-(
Hi,
welcome to the frustrating world of the Freelander!
I have an older, 95k miles but still going strong, TD4 (as a 2nd vehicle) which I really like driving, but I dread the cost of something like the clutch and dual mass flywheel replacement if/when it happens. They're great when they work but are a complex vehicle to maintain in tip-top condition and have a few built in flaws so you have to stay on top of things as they get older.
However, the payback is the sense of smug satisfaction I get when when my £2k's worth of Freelander sails past £30k BMW's and Mercs on the inclines when we get a fall of snow like last weekend. I have never had a problem moving around safely in the foulest of weather and that's worth a lot. I probably should charge a fee to the several people I have towed back to level ground or out of ditches and put the money towards maintenance of the old girl!!
Colin
it's not for nuffin they're known as Freeloaders.... I reckon I'll be sticking with my Series 3 for a few decades yet...
