Lord Nibbo":23tdh2kg said:
I've looked at most of the laminates manufacturers and my only contention was it's only 0.8 mm thick some makes are even thinner.
Laminate thickness is down to whether or not it's vertical grade or horizontal grade. HG is made for countertops and is thicker. Laminate is about as hard as steel, it's main component being phenolic plastic (as in Tufnol). It doesn't need to be any thicker and it will last 15+ years in the average kitchen....
I'm going to use a polycarbanate sheet 6mm thick.
Why not go and cadge an offcut/scrap piece of acrylic (Perspex) from the local sign makers? It's harder than polycarbonate, so it wears better, and if you do want to go mad and buy some it's also cheaper than polycarbonate as well as being a darned sight more rigid and easier to get a decent edge on.
Scrit
