Laminate sheets
SMALMALEKI
30 Jan 2018
Derby
h2k4pq
I’m new Tom woodworking and an absolute weekend woodworker. While researching different workbench tops I learned about laminating timbers and producing a sheet.
However there are some sheets in the shops which are made from shorter pieces of wood. Does anybody has any how to guide to make these? I was thinking of making sheets for testing it from off cuts.
Can you show us a picture of what you mean please? You say laminate but I think you're describing a short stave type block.
Perhaps this one is a better demonstration of what I’m describing
    103.6 KB
These counter tops are machined very precisely to give seamless jobs across the long grain and end grain. It is possible to replicate using a planer thicknesser and a finger joint router bit (or more likely shaper), but you'll struggle immensely to get it anywhere near as seamless.
One thing to bear in mind is that every joint is a potential weak spot. If you were to try and join wood like this without the same industrial presses and whatever curing techniques / machines they use, you'd probably end up with it warping all over the place.
