Knock down joints
Dave_G
6 May 2005
Manchester - UK
Neil,
At first galnce these seem to be spot - will have a more detailed look later today - thanks for the help
RogerS
20 Feb 2004
In the eternally wet North
Dave_G
I've used the ones that Neil's suggesting (plus others from the Screwfix range). All worked well. I would recommend using a drill press to ensure the pilot holes are vertical.
There is also some mild brakout of the Contiboard surface if you're not careful...assuming that's what you are using, of course. Never found a simple cure.
Roger
