SteveF":26hdotw4 said:I have little option of a drawing,it is in my head sadly
this is my inspiration
http://www.bexfield.co.uk/02/d706.htm
i want to hinge from bottom rather than sides with a full width\height flap that is drilled out to accommodate the drawer knobs
Steve
custard":x0ay7m1p said:My inclination would be to have the fall properly hinged with no "sliding" facility. Maybe you could line it internally with green baize, in effect providing a shelf for polishing the cutlery? If you think the fall is just too large and clumsy then maybe there's a way of using a piano hinge halfway up the fall, so that it could be folded in half and take up less room?
SteveF":2domc9ba said:custard":2domc9ba said:My inclination would be to have the fall properly hinged with no "sliding" facility. Maybe you could line it internally with green baize, in effect providing a shelf for polishing the cutlery? If you think the fall is just too large and clumsy then maybe there's a way of using a piano hinge halfway up the fall, so that it could be folded in half and take up less room?
would a card table hinge(top mounted) be suitable?
I have looked at solid brass piano hinges and the quality seems to be poor
Steve
custard":2uc8ssxh said:SteveF":2uc8ssxh said:custard":2uc8ssxh said:My inclination would be to have the fall properly hinged with no "sliding" facility. Maybe you could line it internally with green baize, in effect providing a shelf for polishing the cutlery? If you think the fall is just too large and clumsy then maybe there's a way of using a piano hinge halfway up the fall, so that it could be folded in half and take up less room?
Steve
The solid brass piano hinges (not the plated brass ones) from Ironmongery Direct are reasonable quality,
https://www.ironmongerydirect.co.uk/bro ... t_index=18
I've bought in slightly better ones from a couple of the specialist US suppliers but with customs and shipping it gets expensive. All piano hinges look worse when you look at them loose, and better once they're fitted.
The card table hinges you suggested might work, but they'd have to be recessed into the sides of the fall, if they stood proud they'd leave a gap. The other question about card table hinges is, are they 90 degree hinges (like butler tray hinges) or 180 degrees? Off hand I'm not sure. Horton are a good source for quality specialist cabinet hinges,
http://www.horton-brasses.com/butlertrayand-1.asp
