Knackered T5 bearing
RogerS
20 Feb 2004
In the eternally wet North
This T5 router has had hardly any use but has now died. The top bearing looks as if it either seized or over-heated as the plastic housing in which the bearing is located appears to have melted! Anyone else come across this problem?
You can see a bit of the plastic just up a bit from the red wire.
Thank God I still have my trusty Makita !
Not at all uncommon. Once a problem starts in a bearing the result is often heat and in a plastic housing , the heat can't get away.
Trend spares are often dearer than their equivalent DW part - the routers are all but identical.
hth
