kiwi1
user 19915
25 Jun 2014
Anyone know kiwi1 who used to be on the forum who wrote this article ?I would like to get in touch with him regarding the same problem,s below with my saw and what he did to resolve the problems
MOCK
Hi Re. the LUTZ table saw.
Have you resolved the problem yet ?
I have one of these machines branded as Record Power RSTS12. Neither Lutz or Record want to know about them. I have not been able to find a manual for it but have had it stripped down completely. It seems to suffer from some serious design faults, which I have modified some of them and it is working fine at the moment. Unfortunately, I did not photograph any of the mechanism before I stripped it. I will detail the problems, then my modifications for it. 1/. The rise and fall mechanism was bent as follows:
2/. The winding handle worn on the inner surface of the handle
3/. The handle inner surface wears the front surface of the tilt panel
4/. The 10mm threaded rod that fits into the handle was bent
5/. A 2.5mm thickness boomerang shaped piece of panel steel raises the motor mounting also bent.
6/. Motor Mount panel bent/distorted.
If you still require the info I can detail the repairs and mods.
cheers
