Kity 618
marcros
11 Feb 2011
Leeds
I was flicking through the manual for my 618, having scanned it for somebody.
In it, it mentions using the "special screwdriver" when changing the blade to poke through a hole in the table and lock the blade- I didnt know about this feature. It also calls it a stop rod.
Does anybody have one of these that they could measure? I cant access the hole in the spindle to measure the diameter of it. If not I will have to use some threaded rod to see what fits, but that does require buying a few sizes of it.
Drill bits make very good gauges and most people have some.
that is an idea. If i have a long enough one. I would guess that it is m6. everything else on the machine seems to be unless it is huge.
I don't know if this will help but I have a 617 saw and there is no way to lock the shaft but I also have a 627 spindle moulder and there is a pin with that to lock the shaft and it is 8mm dia. In my experience of Kity machines many things were standard across the range.
Hi Marcros,
My 618 is currently in bits, and I just checked the hole dia.
6mm drill bit is loose, 6.5mm drill bit is snug and 7mm bit wont fit in.
My thinking is, a 6mm dia rod will do the job.
Tim.
My old Coronet Major had a left hand thread on the arbor nut. I used to slip a meaty drill in one of the gullets, so it was trapped between table and a tooth. That would hold the blade well enough to remove the nut. If yours is a right hand thread, couldn't you make a wedge to slip down between the back of the blade and the throat?
It is also left hand thread on the 618. I will make/find something 6mm ish and epoxy a handle on it. I have always held the teeth into a block of wood until now.
No need for a handle Marc. Just slide the drill, across the table-top until it bridges the throat, and is under a tooth. I suppose a piece of hardwood would work, as long as the teeth dig into it.
HTH
Hi
I'd be tempted to find an old screwdriver with the correct diameter shaft - the steel will be a lot better than mild steel rod which may bend in use and make removal difficult.
Regards Mick
