Rob_H
- Joined
- 12 Feb 2005
- Messages
- 650
- Reaction score
- 11
I recently bought a Kity 613 bandsaw and replaced the blade. It seemed to be ok and I cut a piece of a small cherry log I had stored for ages and some resin seemed to come out and cover the blade. When I checked the wheels they are extremely sticky and I can’t get it off and it’s been about a month. The top wheel doesn’t have a rubber tyre - not a rubber one anyway - on it and the bottom tyre is worn in places. How can I remove the rubber tyre as it seems to be stuck to the wheel and not sure if the top wheel is right. It has a grey thick surface on the wheel. Not sure what material is and if it then should have a rubber tyre on it. It ran ok for a while but the blade now wobbles and jumps off. I have watched loads of videos and spend ages tensioning and thought I had it ok and it worked fine for a short while but jumps off again
