Kitchen cupboard fittings
SteveF
16 Sep 2013
Maidstone
can anyone recommend the best
a) hinges soft close for suitable for face frame
b) runners soft close 550mm
c) hinges for a corner unit so that 2 doors open from 1 side (2nd hinge fitted to 1st door)
Steve
Hemsby":1ry6q91i said:
Can recommend these,
http://www.ebay.co.uk/itm/201145053505#shpCntId
Don't be put off buy the price, they are good quality and stand up to the job.
I fitted these to our kitchen units & a rental property. My son has also fitted them in his rental properties.
My last delivery cost for 20 was £1.94
could i pack behind hinge to compensate for face frame?
or should i buy special ones ?
Steve
Sorry Steve I obviously did not read your post correctly #-o, I think these hinges are designed primarily for frameless doors, probably like most things fitting modifications could be made (hammer) if the correct hinge is not available.
Keith
Sorry, only just seen this. Posted a similar hinge response in this thread:- concealed-hinges-for-inset-face-frame-doors-with-an-offset-t87922.html
Just fitted some drawers with Grass Dynapro runners - nice, good adjustment, clip-on fittings front and rear and rated at 40Kg/pair. I bought mine from my local yard, but there's no shortage of suppliers online if you Google them.
HTH Pete
I've just fitted my kitchen from Wren and they came with Blum softclose clip on hinges. I was familiar with Blum quality bit had never used clip on hinges before - they are excellent if fitting units as the doors can be removed to reduce weight, plus if shelves need to move they can be taken off and clipped back on without losing any adjustment. i just bought a set of blum integrated soft close with carcas fitting from screwfix (£9.99?), but dearer than posted by hemsby.
Dave
