I think what daniel is getting at with the above post, is that ideally the boards would be stickered ( stacked with spacer timbers inbetween to allow airflow around all faces of the boards )
Couple of things..... firstly, have you sorted out the storage issues? I.e dry with air circulation? If they took on a lot of moisture, presumably they are in an outside shed or single skin garage etc?
I would prioritise getting the stickered and dry them out ( heat, dehumidifier etc ) and then go buy yourself some oxalic acid.
Once dry and lets hope they dont cup/ twist / bow , mix a tablespoon of oxalic with a mug of hot water, liberally paint on and hopefully it'll return to fresh looking timber after 10 minutes. May need a couple of goes. Then rinse with clean water and dry it all out again ( stickered , dehumidifier )
Or send them to me, my tower scaffold needs a revamp
