• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Withdrawn Keeping : ) Nova supernova 2 chuck - £60 - local pickup only (SW Devon).
captainpk
12 Nov 2012
Devon
Hello,
I am looking to sell my supernova 2 chuck - it fitted my record DML36 SH lathe which I believe the thread to be 3/4" x 16 TPI - the chuck has an insert to reduce the size to fit the lathe (not sure on the size).
Box it came in is a bit knackered and if I don't manage it, it needs a bit of a clean but all works - missing the alan keys and probably the main spanner but does the main one for opening and tightening the chuck : )
  • 100mm diameter, high tensile steel, nickel plated body
  • Self-centring, takes up to 500mm diameter swing
  • Ideal chuck for the ambitious woodturner
  • Auto-Stop feature prevents the jaws protruding from the body of the chuck
  • Duracon composite backing plate with 24 division indexing
  • Plate also keeps dust and debris from chuck’s mechanism
  • Main body supplied with 50mm jaws, Woodworm screw, chuck key and tools
NOVA JS50N 50mm/2" Jaw Set
  • The standard NOVA jaw, a versatile all round accessory
  • Able to handle both bowl and spigot projects
  • Maximum grip, provided by the dovetail cross section of jaw
  • Expands into a recess between 51mm and 72mm diameter
  • Spigot range from 42mm to 64mm diameter
  • Square timber between 31mm and 52mm
NOVA JSPIN 25mm/1" Pin Chuck Jaw Set
  • Useful jaw when turning free form edge bowls
  • 25mm extended jaws act like a pin chuck expanding into a pre-bored hole
  • Longer stand-out of the jaws allow for a very powerful spigot grip
  • Expands into a recess between 26mm and 46mm diameter
  • Spigot range from 10mm to 31mm diameter
  • Square timber between 7mm and 38mm
NOVA 101214 Right Hand Safe Lock Woodworm Screw
  • A quick and easy method to mount small bowl blanks
  • Provides a secure mounting when turning the outside of bowls
  • Strong thin edged thread form cuts into wood for maximum holding power
  • Square shank ensures positive location into the chuck body
  • Available in right-hand and left-hand (for outboard turning) versions
Hello, Cap'n
I'm in mid Devon, and interested in your chuck. I haven't turned since schooldays, some 60 odd years ago, but just got a lathe to tidy up, an early Axminster import. I think it has 1 x 12tpi thread, so I'd need an insert for that size. As the chuck is plated on steel, is the plating more or less intact, or is there loads of rust from damp shed storage? I think we are still in lockdown? My wife is shielding so we haven't been going out much since last March! Expect we could sort something out, mabe PM me?
regards
