Just another owl!
scrimper
27 May 2007
Glos England
Made this for my Sister, we call her Lady Bucket (Bouquet from TV keeping up appearances) cos she is fussy and a bit snobby! She admired the one I made with the Geese on and she likes owls.
    62.6 KB
That's a fine piece of work scrimper. Can I ask what timber have you used and what size of blade to cut round them trees? :D
It's just recycled stuff that was thrown away by others but treasure to me! The owl part is some old plywood from the sides of a chest of drawers it had some old veneer on but underneath it was good ply so I removed the veneer with a chisel and cleaned it up with a random orbital sander. the backing and surround was an old mahogany door frame that was given to me as firewood! (the frame is actually made of 4 strips glued side by side but as the grain is the same you can't see the join)
I used a grade 5 blade for the main frame with a grade 3 for the leaves. The main part I used blades grade 3 and for the finer detail a grade 1 blade. Approx 6 blades snapped when cutting the detail all of them were FD reverse blades, eventually I switched to the cheaper Niqua plain blades which did not cut so fast but none broke.
I can see now why you use a No1 blade for some of your work, you must have the patience of a saint. Very fine detail and a great credit to the art of scroll sawing.
