Just a test..
Scott
18 Oct 2004
Don't mind me.....just trying to figure out how to post pics!
If this works I might even take the camera to the workshop in future. If not I might lose patience with it in short order :?
here goes......
Scott
18 Oct 2004
Doh! Helps if I don't just post the thumbnail! :roll:
That's better!! Knocked that wee table up from a scabby old bit of 3 x3 sycamore with a big banana bend in it that a bloke in a timber merchants gave me for nothing years ago!
Scott
(who found that surprisingly easy ..... thanks for the tutorial Adam!!!) :D
jasonB
26 Nov 2004
Surrey
I'm not seeing any pics in either post, just the white box with red cross
Jason
Scott
18 Oct 2004
Maybe I spoke too soon! :roll:
I can see them myself. Wonder what I haven't done!?
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Scott, nice bottle of French bierre and an even better side table. Once I'd copied and pasted, the image appeared in the 2nd post.
Scott
18 Oct 2004
Thanks Noel. Any idea why the pics aren't working properly?
Scott
Scott
18 Oct 2004
Tried that Aldel but it doesn't seem to work!
I'll have another play.....
Scott
Scott
18 Oct 2004
Thanks Dave. Can you see the edited one above?
I can see it but it's the same link as earlier when Jason couldn't
Scott
Scott
18 Oct 2004
Still working for me! :)
I'm bored with this now though!! Enough for tonight!
Thanks for your input guys! :D
Scott
Adam
10 Sep 2003
UK
Scott,
You are linking incorrectly. See this post:
https://www.ukworkshop.co.uk/forums/viewtopic.php?t=4002
Code:
http://www.pbase.com/u35/leitch47/large/40493973.Table2.jpg
The above is the link you are using.
The below is the link I *think* you should be using.
Code:
http://www.pbase.com/leitch47/image/40493973.jpg
and in IMG tags
Basically, I reckon you are "right-clicking" the image to get a copy og the URL - but you should use the one in the toolbar above.
Also, I don't know why direct linking to your account is banned? Are you on a trial membership still? If so, you nede to upgrade to a paid subscription possibly?
Adam
Adam
10 Sep 2003
UK
Thats probably becuase you have the cached on your harddrive. None of us can access it, so it "appears" to work for you when not working for us!
Adam
Scott
18 Oct 2004
Thanks Adam! I had tried both URL's and I knew which one i should be using because I checked the address of one of your photos for the correct format but it didn't seem to be working. Came to the same conclusion last night about pbase. It was only on trial subscription
I've just coughed up the cash so hopefully it should work now! :)
Do you copy the URL from the address bar and then have to manually add the .jpg file extension every time?
Appreciate your help. Cheers.
Scott
Adam
10 Sep 2003
UK
Sadly, yes, this is how I do it. I reckon it'd be worth submitting a request to pbase for them to provide it. Someone (maybe photobucket?) can't remember who - does this already, even providing the
tags as well. I reckon the others will follow suit shortly.
I can see your picture fine now!
Adam
Travis Byrne
4 May 2004
Oklahoma, USA
Scott
You are not alone :D :D :D
I have spent the last 2 or 3 months, off and on, trying to post a pic.
I have used 4 differant pic hosting sides. The last one is photobucket and it works for me now.
You must take into account that I am old and slow, handicaps that are hard to overcome. :oops: :oops:
I see the pic now and that all that counts.
Travis
