Joining bay window boards
niall Y
1 Nov 2018
CARDIGAN
Hi All,
The idea of using a solid un-joined MDF to cut out an L- shaped window board is OK. in theory. The problem, as I see it would the bull-nose moulding to the front of the board, unless, you omit this detail and keep the front square.
The description of the OP's joint as " Mason;s Mitre".is not quite right. With a true Mason's Mitre, both the boards would remain the same width throughout. The boards would then be butted together, and a bull-nose routed along their front face. Where the cutter leaves a radius at the junction of the boards would then be carved with a sharp chisel to square it off to give the appearance of a mitre - so not really a mitre at all. Niall
Bellyboy
17 Nov 2021
Wisbech
Imagine if someone actually did this...
I use to do this most of the time. Always did a template out of thin hardboard first and then transplanted onto mdf then cut , planed and bull nosed it. If i had a few to do i found i could alter the hard board template by knifing it and adding bits by layering if it was short in places.
Limey Lurker
16 Sep 2006
The smaller run of window board is not confined by a wall on the end so it should be easier to get them to mate properly. I would definitely groove along the entire end of the board though as you've suggested. Thanks for the advice!
If you groove the entire end of the board, then why don't you use a spline, instead of biscuits, and get 100% alignment?
