jig for random orbital sander?
Stooby
13 Mar 2014
Upwood
Would it possible to make a jig to hold a random orbital sander so that it can be used almost as a disk sander?
By "as a disk sander" do you mean fixed and you bring the work to the sander, or are you thinking with a table and the full setup for sanding mitres etc?
Hello Marcros. Currently I would like to be able to take the price to the sander so that I can better see what I am doing when smoothing curved prices.
I would like to move on to some box making in which case being able to sand strait and mitred edges would also be good to do.
Hmmm. The first is easy enough to knock something up- even just hold it in a workmate/vice. The second would be more difficult. There are many ways to cut mitres- a disk sander is one that some people use successfully. Personally I would choose another method. A shooting board and plane would be the cheapest and quietest. The same setup could be used for straight edges too.
I have had a shooting board recommended before, are there any easy to follow plans anywhere that aren't going to assume I have a workshop full of tools?
Hi
I'd reconsider your idea if I were you - the ROS operates in a different way to a disc sander, (DS). With the DS the abrasive is moving at a constant speed in a constant direction and therefore it is relatively easy to restrain a piece of work against it. The ROS abrasive action is random and therefore more difficult to restrain the work.
I'd go for a dedicated disc or belt sander or one of the other more manual options.
Regards Mick
