Charlie Woody
I have a JET Table Saw JTS-250(S) (quite and old model with the sliding table) and want to make a cross cut & mitre sled for it. The sled will be similar to http://www.eaglelakewoodworking.com/pos ... -Sled.aspx
If you are familiar with this saw there are two features which impact on making a sled (1) there is only one mitre slot to the right of the blade (2) The instructions for mounting the sliding table require this table to be 0.4mm higher than the main table.
I have tried to get the two tables level with each other but have failed. The sliding table just does not want to lower level with the main table .... if one end goes level then the other moves out of level!!
So I wonder has anyone else made a cross cut sled for this saw and how did they overcome this problem?
All suggestions welcomed
