Jet JWS 34LX Spindle Moulder Help
Chippymint
1 Jun 2016
Devon
I have the above and I'm hoping someone may be able to help please.
I've had this from new in 2003. I am trying to remove it's Arbour (for the first time) so I can start using the router facility. My problem is that the Arbour will not budge and won't come out. I've followed the manuals instructions. All the nuts are loose and removed.
From what I can see the Arbour shaft has a shank. The shank slides into the main shaft and is held in place by the Arbour shaft nut and underneath drawbar and nut.
I'm guessing that it's just seized from not ever being removed but there maybe something I'm missing or there is special technique.
Just hoping someone has had the same issue and could tell me how you sorted it please and/or how you remove it?
Many thanks
