The digital display on my 3520B lathe has suddenly started displaying "0" regardless of actual speed or direction of rotation.
The speed is sensed by a proximity sensor (proxy) picking up the four lobes of a rotor as it passes the proxy.
I have checked the air gap between the proxy and lobes; about 1mm, unchanged from previous.
There is no dirt on the lobes or proxy.
There is no visible damage to the proxy or associated electronics.
A red LED on the proxy remains lit whenever the lathe is powered up whether the lathe is rotating or not.
Speed control is unaffected, and speed display is not really needed anyway, but it's annoying me so I want to fix it. The proxy is probably an inductive device, which are known to fail occasionally, but I'd be grateful for any suggestions as to the likely cause or fixes.
Duncan
Duncan
