Hi there still looking for a set of planer knives for an ELU DAH 176. Can't find them anywhere but have come up with a solution depending on cost. I have been searching online for ages and the blades I need are not available unless I spend a fortune. Evberybody who has returned my email say the same. I have found a set of double edged blades for a JET JPT310 planer. They are 2mm wider and don't have the slot on the reverse. I am looking for someone who can regrind them from 18mm to 16mm and take a small 2mm x 1mm linear groove out on the reverse.
This is the profile I need 210mm long 16mm wide and 3mm thick with groove 2mm wide and 1mm deep
These are the blades I found. Obviously too long but 18mm wide and I think 3mm thick. I need someone to adapt/machine them down by 1mm each side to 16mm size and also create groove. Have no idea is this is possible. I can get some originals from germany but they cost more than the planer is worth.
Any help or a point in the right direction would be most welcome.
Alasdair
Alasdair
