J_SAMa
Even in a bevel down plane, where the bevel angle doesn't affect the angle of attack at all... Does it have to do with the balance between sharpness and edge retention?
Sam
Sam
To work properly, the cutting edge needs "relief", or clearance, immediately behind the edge. Because wood is a variably compressible material, the relief angle needs to be at least 10 degrees to cope with a wide variety of types. It's impractical to sharpen a metal blade to less than about 20 degrees (& even that is too acute for many) so the compromise is usually 25 degrees (usually in the form of a secondary bevel). Add 10 degrees for relief, and this sets the minimum bedding angle for a bevel-down blade at 35 degrees. That would be a minimum, and would be ok for some woods, but could cause problems in many others, which is one reason you just don't see planes with bedding angles between 30 & 40 degrees, they are either >40 or <30. Once you go below 30 degrees, the practical solution to the relief problem is to flip the blade over, in which case the bedding angle is now the relief angle, and the bevel angle becomes the 'cutting angle'. A 'standard' block plane has a bed angle of 22.5 degrees, which, with a bevel angle of 25 degres gives you a cutting angle of 47.5 degrees. Almost the same as the 'standard' 45 degrees of the most familiar bevel-down bench planes.
Of course there is a little more to the function of planes than cutting & relief angles, but these do set some important limits to design.
