Is a Ferm FKZ-250 any good?
A
Anonymous
Guest
Just wondering if anyone here has got or has seen/used this mitre saw at all?
Im trying to cut some accurate mitres for a simple frame but so far ive found nothing that can cut them to a proper 45degree angle so I was looking at these machines, for £50 or whatever it seems good value & while I dont need the best of everything as I cant afford a top quality make on every piece of my equipment as I would need to be rich, I just want something that can do the job nicely, im very happy indeed with my Ferm biscuit jointer & wondered what this Ferm was like.
The other one I was thinking of was this one for £120 with a laser sight:
http://www.shopv.co.uk/productfinder/M2 ... LASER.html
Any thoughts or recommendations?
Nick.
A
Anonymous
Guest
Norm fan
Not sure about the ferm one but i used a B & Q one for quite a few years,
IT took a bit of adjusting to get it to cut at 45 or 90 and i fitted a new blade (i recomend you do that with any budget saw) but it cuts fine and i have got the bigger sliding saw now with a 80mm x 300mm cut :D .
Mick
A
Anonymous
Guest
I've just seen a TV ad from B&Q for a compound mitre saw for £26 :shock: (Performance Power range I think)
I dont know if its any good though! :?
Peter
GrahamC
16 Oct 2002
Fife, Scotland
If you are not doing lots and lots of cuts and the timber you are cutting is not too large, it might be more worthwhile to buy a traditional hand box mitre saw.
Rutlands sell a couple that I have used before and they were very accurate (the name escapes me and I am too lazy to go and look it up just now, sorry :roll: )
For your £50 you will get more accuracy with these than you will with a powered beasty, but I know, they are just not as exciting :)
GrahamC
16 Oct 2002
Fife, Scotland
NormFan, I got over my bout of laziness and looked up the saw in Rutlands. It is made by NOBEX and is accurate to 0.08degress, which isn't too bad all in all.
A
Anonymous
Guest
I had one of them but i could not find a way of pluging it in. :lol:
Actualy i still have one and still use it for very fine work (if i need to)
Mick
A
Anonymous
Guest
0.08 degrees? that sounds good enough to me, I think I will give it a try then.
Thx everyone :)
GrahamC
16 Oct 2002
Fife, Scotland
Be careful NormFan, buying tools without a plug!! Just make sure it doesn't become a bad habit :)
Seriously, in my experience they are excellent saws and well worth buying.
