Insert Nut Advice
I suggest you experiment to find the optimum tapping drill to suit your timber to get a good hold and a flush fit.
Use a lip and spur bit for a good clean hole.
hth
Bob
In my experience they take quite a torque once nearly seated - so it's worth buying the extra long Allen keys. I wouldn't recommend trying to use a power tool on them.
Generally I use 7-7.5mm drill depending on material density - I would recomend a T-bar allen key to put them in as then you are pushing square into the material (which is harder to do with the L-shaped keys)
Drill a very shallow recess for the head with a small forstner bit (select the inserts carefully as they are not always concentric)
I find that in softer materials you need to lean on the key quite hard as you screw the insert in or the rough thread can act like an auger. P
