Jimmy69
Hi. I've been using my Inca universal table saw after a re-build and I need a new blade. The blades are 160x15mm which is just the wrong side of odd. I can't find 20mm to 15mm reducer rings and the saw also uses a cupped flange making reduction ring a bit iffy.16mm more holes are pretty common but a 16 - 15mm reduction ring is also hard to come by.
I have some festool 160×20 blades I'd like to use if I can get the correct RRings
What are my options for safe usage guys?
