Never seen an I.Sorby saw with a double Mr Punch logo before and then three turn up all at once, I was lucky enough to buy two of them.
The larger 14" is the easier of the two, I've plenty of screws saved from derelict saws and despite the shallow teeth it does feel reasonably sharp. So might attempt to a quick sharpen and then go from there.
The 12" is a lot more challenging. The original plan before it arrived was to follow AndyT's excellent example here
bristol-saw-restoration-t86283.html
but when it arrived it was immediately obvious more drastic action would be called for.
The saw plate is too thin, flexes all over the shop and has a lovely S shape. Should be fun and even if I can get the screws off it doesn't mean the handle will come off, the 14" has no screws but the handle isn't going anywhere.
