johnelliott
At the moment I cut the tongues on the ends of the rails (I make kitchen doors, maybe 20 a week) using a workshop-made tenonning carriage which slides across the router table, running against the fence. Usually the system works well, but every now and then the tongue is cut inaccurately, usually too low because the carriage has ridden up slightly or sometimes at a slight angle because the carriage isn't rigid enough to ensure that the wood is held absolutely flat.
I think I could solve these problems by constructing a router table that incorporated a proper sliding table, something that runs on proper bearings and slides that prevent the table moving in anything other than a straight line.
I could construct something using slides from a firm like www.hepco.co.uk , but before I go that far I though I would ask here and see if anyone knew of something readymade that could be adapted?
I know people have made stuff like this using drawer slides etc, trouble with those is that there is usually little control in the vertical plane, the system relying on gravity to keep the table moving in a straight line.
Any help would be much appreciated
