DaveL
I looked at Tonys thread about upgrading his morticer and made a note to do the same sort of thing for mine. Well I got round to buying the cross viceyesterday from Machine Mart, as they have opened a branch in Colchester, only 15 miles down the road.
I have spent today modifying the vice and morticer. I drilled and tapped the holes to allow the top slide handle to face the front. I made a spacer block from some very hard wood that came in a load of fire wood. 8) I removed the metal jaws and made some nice Ash ones. I drilled the table on the morticer to allow the vice to be bolted down. I even drilled the bench to bolt down the whole thing as I was nervous of tipping it on my toes. :shock:
I came to the last part of the set up, checking that the slide movement was parrel to the chisel. It was a little out,
I slacked the bolts and nudged the vice. I recheck it, it was a little out :evil: . At this point I think I lost touch with reality, I took the vice off the table and filed the holes into slots. :shock: I put the vice back. I check the alinement, it was still out. :x
I took a step back and thought about what I was doing, something was not right here and I should of seen it. On checking I have found that over the 5" length of the jaw the vice is 75 thou out of line with the slide. I am I being too picky? Should I try to take to back or should I just plane the ash to get it back in line?
