Mick, if used as I suggested the energy doesn't come from the engine, it would come from deceleration, using the energy from the IC engine to spin it up would increase fuel consumption.
Vertical rotation east/west or north/south? The idea was tried years ago by CalTech? They stated that you could spin it up at home, drive to the nerest airport and take a 6 month holiday and when you returned there would still be sufficient energy to get you home, provided it was a straight line! :lol:
Vertical N/S, along the axis of the vehical, assuming a fixed gimbal, should result it movement to the left when a force is applied to the right, surely?
ie, Sopwith Camel, bike wheel?
The amount of energy must be a factor of speed and mass, a large dia, slow flywheel storing the same energy as a small dia one at high speed. But there will be difference in flywheel acceleration/deceleration in the same way that a heavy rimmed flywheel produces more torque than a heavy centered one does.
Roy.
