Hi. iI've been asked to transform a large but low eucalyptus coffee table into a dining table, so far so good.
Had a look this morning, and the ornate legs are solidly attached, I assume there will be a central threaded rod into an inset nut or similar, and then glued:
Even with as much twisting force as I could manage there wasn't the slightest hint of a rotational movement, and every foot is, to a lesser or larger degree, split like this one shown.
The piece of wood it goes into is solid and integral to the table, and I can see dowels.
My fear is that applying enough force to break the glue bond would split the feet (which need to be preserved as they want them at the base of the new legs I will make).
Not a local item, bought 20 years ago in Australia from a local maker.
How would you go about freeing those feet? I have considered a jigsaw to cut them off, but it would need a long reach. I would anticipate fixing the new legs with glue and 4 x dowels
