How would you go about rebuilding this back gate?
LFS19
21 Oct 2015
East Yorkshire
Hi everybody,
We have this back gate at my grandparents house that's in pretty bad shape.
Some of the wood has gone rotten, and it's started to sag somewhat.
It's needed doing for a while, and I've offered to help them rebuild it.
I've been procrastinating over it for a bit, and have been somewhat afraid to properly look into it for fear I'd start it and then something would go wrong and they wouldn't have a gate at all.
It's got to the point now where the wood has started going rotten, so it really needs to be dealt with before it ends up no longer serving its purpose.
The overall design of the gate, if I were to build it to the same spec is pretty simple, as you can see.
The bit I'm unsure of, though, are the rivets and bolts.
I'd be fine with building the thing, but to actually hang it I don't really have any experience with.
As you can see, the gate is attached via three steel poles; two either side and one in the middle where the side door is.
You can't quite see the far right in the pictures, but that part basically mirrors the left hand side.
I'm not sure if I were to rebuild it, how I'd attach the new gate to the existing steel poles.
I'm not sure weather I can reuse the bolts, and to get new ones that fit might prove challenging.
Maybe they'll be stuck in here and won't come out at all.
I was wondering what you thought of the project and what I should do?
As I say, to essentially make the same gate as is on there and hang it the same way with those three poles would seem the option I want to go with, I'm just not sure whether I'll be able to use those existing poles if I can't find new bolts that fit, the old ones are stuck riveted in there etc
Just a little nervous as to not start it and then realise half way through that the existing poles can't be used, and they'll basically be needing a whole new design.
It's about five meters wide, and 5ft 11 inches tall.
What you have is four parts:
The main part opens with a latch in the middle and then two bolts at the floor to allow the car into the garage.
Then to the right, you have a side door for people to walk through without having to pull open the double doors for the car.
Next to that side door you have a gate that mirrors the one at the far left but obviously doesn't open.
Thoughts?
Thanks a lot!
Sent from my iPad using Tapatalk
    194.1 KB
    184.8 KB
    192.3 KB
    182.9 KB
The hinges are standard that you can buy at any timber / fencing merchants. The bolts will be just a standard size. So for both issues I wouldn't worry too much.
To hang the gate, my method is simply to place it where I want it to go, wedge it to the right height / level, fold over the hinges, pull down on them and drill, through a hole closest to the edge of the gate for both top and bottom hinges. Place the bolts through and if I'm happy with how it's swinging drill and bolt the rest. This method allows me to increase the diameter of the holes I've drilled if it needs adjustment and then tie the gate securely with the remaining boots in the hinges. Pull down on the hinges to take out any slack in them otherwise the gate will drop from where you think it will be. A good batten clamped to the fence / gate keeps the gate upright and steady.
The hinges look ok, I would think you could leave the hinges on the posts, wedge the gates in position and mark then drill the hinges.
The gates can be set so they are high on the non hinge side to allow for dropping. Also, There is always some play in the pivot point of the hinges so make sure the top hinge is pulled away and bottom hjnge pushed in to allow for that.
Sorry for the late response, that makes a lot of sense!
Thank you both for your detailed replies.
Seems fairly simple to do, so I'll give it a go.
