How to??
mailee
26 Jun 2005
grimsby Humberside
Can anyone tell me how to change the brushes on a Elu MOF96E. I have the manual with an exploded view but it looks a little complicated and I should hate to bu**er it.
SketchUp Guru
12 Apr 2005
Rochester, MN USA
I found an exploded view drawing on the internet and it doesn't look too bad. Only shows one brush but I find that hard to believe.
Anyway, proceed slowly on a large clean work surface. Lay the parts out in the order they come off. If looks like maybe the first step is to remove the screw near the power cord entry.
Just be careful as you reassemble it to make sure you don't pinch any wires.
You can do it. I have confidence in you.
gwaithcoed
23 Feb 2005
North Wales
Hi mailee, I've got an Elu OF96E, I don't know whether there is any difference between yours and mine but I've just had a look at mine and if you remove the two screws holding the top cover on and pull off the cover then you will see the brushes. They are held in place with retaining springs which can be pulled back to allow you to remove the brushes. The electrical connection is just a pull off spade terminal.
Hope this helps
Alan
